Just wondering, is there a list anywhere that shows in order, the fastest curing wood to slowest curing? Seems like this would be a sticky on here.
boatboy63 said:Just wondering, is there a list anywhere that shows in order, the fastest curing wood to slowest curing? Seems like this would be a sticky on here.
Yes, it ranks the wood once it is seasoned. But that doesn't tell how fast it seasons.gzecc said:Here is the list I use. The bottom has seasoned ranking.
http://mb-soft.com/juca/print/firewood.html
Thats what the green rating is. Its excess moisture needed to remove before 20% MC!CountryBoy19 said:Yes, it ranks the wood once it is seasoned. But that doesn't tell how fast it seasons.gzecc said:Here is the list I use. The bottom has seasoned ranking.
What we're looking for here is a list that says, Ash seasons faster than maple, which seasons faster than oak etc. We know the green MC of most woods, but that doesn't necessarily tell us how fast they'll season.
Not sure what your point is as it does not tell you how fast the wood seasons.gzecc said:Thats what the green rating is. Its excess moisture needed to remove before 20% MC!CountryBoy19 said:Yes, it ranks the wood once it is seasoned. But that doesn't tell how fast it seasons.gzecc said:Here is the list I use. The bottom has seasoned ranking.
oldspark said:Not sure what your point is as it does not tell you how fast the wood seasons.gzecc said:Thats what the green rating is. Its excess moisture needed to remove before 20% MC!CountryBoy19 said:Yes, it ranks the wood once it is seasoned. But that doesn't tell how fast it seasons.gzecc said:Here is the list I use. The bottom has seasoned ranking.
Battenkiller said:Here is a table from the U. S. Department of Agriculture Forest Service publication, "Dry Kiln Operator's Manual". It can be found on page 177 at the end of Chapter 7. You can download this manual in PDF form from the following website:
http://www.fpl.fs.fed.us/products/publications/several_pubs.php?grouping_id=101&header_id=p
The publication relates specifically to kiln drying wood, but I'm sure the info in the table is based on the drying characteristics of the mentioned species. It's a start at any rate.
SolarAndWood said:No wonder Big Redd is always touting his Doug Fir.
CountryBoy19 said:oldspark said:Not sure what your point is as it does not tell you how fast the wood seasons.gzecc said:Thats what the green rating is. Its excess moisture needed to remove before 20% MC!CountryBoy19 said:Yes, it ranks the wood once it is seasoned. But that doesn't tell how fast it seasons.gzecc said:Here is the list I use. The bottom has seasoned ranking.
Exactly, it tells you how much excess moisture but it doesn't tell you how fast it seasons.
Does all wood season at the same rate? IE, oak will go from 35% to 30% MC in the same amount of time that ash will go from 35% to 30%? What we're looking for is a chart that says, Oak will season in approximately X many times as long as ash, or just a reference that says x seasons faster than y etc.
The speed at which the wood seasons is not the most important part of the equation. How much moisture needs to be removed from a high quality piece of fuel is. The top 10 green rankings will season the fastest and give the highest heat output.
What else do you want?
Nobody could tell you how fast it will season, unless all the variable are consistent, size of spit, temperature, pressure etc. Its all realtive and there is always a compromise.
The MC doesn't tell the rate at what it seasons, just what MC the wood starts out at.
I always have good luck with black cherry alsojotul 45 said:I have found black cherry to season really fast if stacked properly
rdust said:This shows drying times for 4x4 lumber. I think most of us around here have proven more time is required then what is listed here, it's some type of reference though.
