ok i bought the liner kit and insulation blanket (chimneylinerdepot), rented the lift, ready to go tomorrow am. Watched the vid a few times too..i am confident. But i see (and read) two methods. In theory they both end up the same. I am wondering if anyone can offer up reasons they prefer one method over the other. Some numbers: chim/liner is 35', non-lined brick flue..using 6" ss flex (with wrap). Flue is large (house is circa 1850), i don't forsee any problems with liner being tight. I am thinking about the end of the project and the excess, hacksawing, etc...
1. Is it better to feed liner up from bottom, or drop from top?
2. Once in place but unattached, do i fasten bottom to T first (and cut excess at top), or fasten top to cap first (and cut excess at bottom)?
3. Or, does it matter at all?
took the lift up but the 35' liner with insulation wrap was too heavy to get up, manipulated above the stack... Went in from bottom, first 20+ feet went up fine then the thing just lucked up. I believe it is the wire mesh bunching up. stuck stuck stuck - couldn't budge it with one man at top pulling and me hug/pushing from bottom. It is currently frozen in place, with about 6' left to clear the stack. Thinking about dropping a straight pipe (press-fit) to complete the run...
