Liner install bottm up
Welderman85
350
Chesaning MI
Hello all I did kinda a trial run to install my liner today and from the top down isn't going to happen unless I get taller or build scaffold. My helper and I went tall enough to do it with out the potential of putting a big kink in it
I have a 6" liner so with insulation its around 7 1/2. I have to enlarge my damper opening but that's got to be done either way. The flue has a 45 back then up. Do you think this could be installed bottom up or should I start looking for taller people to help. Lol
If it’s wide open at the bottom, you’ve got a nose cone, a long rope, and strong people at the top to pull, it’s possible.
Is wide open as fas being able to play the liner out. The tile is 13x13 so there's plenty of room in side the flue aft6the damper it goes at 45 back then up. I didn't get a nose cone though. Anyone make there own.
I taped a rope up a couple of feet so it wouldnt pull off, but I didnt have a 45 to worry about. I also rented a lift so I could stand up there, jump up and down, twist it, etc.
Seems to me like I remember someone making a cone...hmm, wonder if I can find that...
I think they used a large plastic funnel...ran the pull rope right through it...
Could just order a nose cone, you are saving hundreds of dollars doing it yourself.
With a cone could it be done from the bottom. Or will.i need a cone either way top down or bottom up
@spudman99 did it recently.
