Ok, first post here, so bear with me.
I am trying to figure out the best way to install our Avalon Olympic wood stove at our new 1960s ranch home. It has a 2-flue masonry chimney right up the middle of the house, close to where we want to put the stove. The west flue is 6.5"x11ish ID and is connected to the basement fireplace (which we don't use currently). The east flue is 7"x7" ID and is unused (I think it used to be connected to the furnace before they upgraded it). Both are lined with terracotta tiles. We want to put the wood stove on the east side of the chimney on the main level, which is convenient since the east flue is open. (It's about 10 feet from the top of the chimney to where we would enter the chimney with the thimble.)
However, after looking into it more (especially on this site, which is why I am now posting my own question here), it looks like my options are limited. The Olympic stove requires a 6" chimney, which would be perfect if the chimney was in good shape. However, after putting a camera down the flue, it doesn't appear the tiles are in great shape: there's small chunks missing from the tiles and some mortar that is missing (or at least it appears that way on the camera: it was hard to see for sure). On top of that, the chimney itself has 0 airspace to combustibles (in the attic, the rafters and ceiling joists are all right up to it). Now, I've seen some varying opinions on how necessary that airspace is, so please chime in.
So it seems that I'm going to need a liner. However, it appears through my research that a 6" flex liner won't fit very well down a 7"x7" clay flue liner, especially if the tiles aren't lined up perfectly and/or there is some mortar sticking out, which there is. (It is a straight run down, so that helps.) A rigid 6" liner seems a little iffy too, but more so because of the snout-less tee you have to shove down there. And even if it did fit, because the chimney has 0 airspace to combustibles, it seems that an insulated liner is required? But because of the tight fit already, it seems that I wouldn't be able to get enough insulation down there even with the stuff you pour in the space after it's installed.
So unless the airspace issue isn't a problem, it appears the only way to use the 7x7 flue with the Olympic is to tear out the clay tile. That seems a little extreme, and I'm not terribly interested in doing that. I'd rather put another Class A chimney up. But then since it would be close to the existing chimney, not only would it look dumb from the outside to have two close together (maybe it wouldn't, I don't know), now the new chimney would have to be 2 feet higher than the old one, which would make it look even worse. Unless, of course, we took down the old chimney, which seems extreme too. One advantage of the class A chimney is that we could go straight up from the stove. If we used the existing chimney, we are going to have a couple feet horizontal offset in the stove pipe just because of where we want the stove.
I feel like I'm in a pickle and I need some good common sense advice on how to proceed. Any thoughts?
