Hello,
I have a majestic factory built fireplace. I Bought some homesaver liner/insulation to use with my quadrafire 2700i wood insert.
QUESTIONS:
1. It says on the flex insulation (see below link) that at 1800 degrees the material turns into a cancer casuing substance
What is with this?!?!?!
http://www.hartshearth.com/productcart/pc/viewCat_m.asp?idCategory=468
2. After I insert the new wood insert into the facotry built fireplace, I am concerned about cold drafts (when the fire isn't burning) coming from the old factory built fireplace -the new wood insert surround is far from air tight. Should I insulate the walls of the factory built fireplace? How? with what?
Thanks
Keith
QUESTIONS:
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thanks
Keith
