Hi,
New to the forum. Lots of info, but just didn't see this. (Didn't know what to search for if it already here.) I have a couple of quotes for a fire place wood insert. The one quote that is different talks about using a different connector system between the liner and the insert. All of the other companies seem to just connect the liner to the insert. This company uses 2 others parts:
6" round connector with 7" (all that is on the quote) > $200
small flexboot 7" ovel to (again, all that is on the quote) > $70
They said something about not having to cut or remove any part of the damper. I assume most dampers are less than the 6" liner and instead of ovaling the liner, they put on 2 pieces 6" round to some 7" oval through the damper, then 7" oval to 6" round to the insert. They said this is done so that if the insert is ever removed and the fireplace is to be used, the damper does not need to be fixed/repaired
My question to the gurus here, is this necessary? Is this the best way to do this? Their price for the main liner is also over $700. So, the liner part from the top of chimney to the top of the insert would be over $1000.
Thanks for all of the great help in this forum.
Dean
Dean
