I was wondering if anyone has actually seen a lil powerhouse boiler? The website is www.lilpowerhouse.com. I have been looking for an inexpensive boiler for my house and was wanting some input on these. I don't know if it would be a good unit or if it is just a lot of talk. I thought picking out a boiler would be a pretty straight forward project, but there are so many choices I'm started to go nuts. Thanks in advance.
Although I think my chemical hand warmers may give me more reliable heat.
But the rest of the story is you will have short burn times at this rate as our furnace holds 1.8 million btu's of dry cured oak per fill!! So if you require 100,000 btu's per hour to heat your house you would have a 13 hr burn time with properly insulated lines, as the cheap lines can loose 2-3 times as much heat as a house requires!! We build an efficient furnace so lets not waste the heat in the transfer to the house!!
