I waited to worst time of year to get one..
Well, yes and no. There will probably be more for sale this time of the year, just because people know to sell one in the summer likely means they will have to "give" it away...but if you can find what you want in the summertime then your buying power will be stronger.
That machine is no pristine queen, it would definitely require a thorough going over, inside and out to make sure it is not rusted out, cracked, etc. Heck, I think I would want to take a screwdriver and remove the sheet metal jacket to be able to spy even the beginnings of any small cracks which could be hard to see from inside the firebox.
Even if it were in usable condition I don't think I'd pay that price for it unless it comes with 20' of class A chimney or something (assuming you need it...or would want to fool around with re-selling it)
The other possibility is that the pictures make it look worse than it is...my Yukon wood/oil furnace was that way, it had very minor surface rust that looked bad in the pics...but turned out to be nothing and it was more than worth the long trip to go get it. But I grilled the guy and his maintenance man about it before deciding to go look at it, and I was 99% sure it was going to be everything I was told it was over the phone once I seen it in person.
Anyways, tell us more about your situation. Size, age and style of your house, insulation level, and is there an existing chimney worthy of being used for a wood burner? If so, flue size and height, interior or exterior, masonry or manufactured? You have existing ductwork to tie into?
Is it possible that a regular ole wood stove would do the job? Lots of people are able to comfortably heat or at least supplement their heat with just a well placed wood stove.
Also, what's your budget on this?
Ever heat with wood before?
Anyone know anything about a Yukon eagle? 112k btu
Take a close look at my avatar and sig line...
