Drifthopper said:
JPl1nh....Your very last sentence......So, if a tree is cut down now, this month, that tree being 12" - 14" diameter, cut to 22" lengths/logs and then stacked off the ground, in the sun, uncovered thru the summer, then those logs/lengths split into halves and/or quarters in September: Will it dry adequately enough to properly burn in December?
Bark is good at keeping moisture in DH, so drop it now, cut it now, and SPLIT it now... Then stack it. You will hear mixed arguements about covering or not, I suspect much has to do with how much rain and humidity you are likely to expect, but IMHO 6-9 months is the MINIMUM time you need to plan for in order to expect cut and SPLIT wood to get reasonably dry, with longer = better...
I have a couple of woodsheds with solid roofs (one old road signs, one corrogated clear plastic) and open sides with roll down tarps. I cut, split, and refill the sheds ASAP starting a week or two ago, and probably finishing by early July. I leave the tarps up all spring and summer, let them down about the time I start expecting snow. This gives me 6-8 cords under cover, and I start burning in the same order I filled the sheds in roughly, starting with the approximately one cord I have left over from last years filling. I want to get almost as much cut in rounds and/or split that I can stack under a tarp so that I'll at least a year ahead, that way next year I can refill the sheds with really dry wood and have even better burning. Goose, one shed with old road signs? That brings all sorts of images to mind, stop, yield, railroad crossing...Tell us more?! I never considered them for building a woodshed with,
Gooserider
