So we just moved into a lovely house here in Massachusetts. The house has a fireplace which we can run independently of the woodstove, but usually dont bother and keep it closed off. great for ambiance, not so much for practicality. and a VC Resolute wood stove which is our primary source of heat besides back up propane.
Weve mainly just been leaving the damper/bypass *just learned how it actually works thanks to google hits on this forum* open... but now I am experimenting with running it HOT ( can only seem to get the stove up to 400 or so right now because not so great firewood... ) with full air and then once i have good coals and fire, shutting it down.
I guess im curious if there are any other tips? Im used to older stoves that dont burn the gasses in the secondary chamber and you entirely control the air intake to control the fire and how long it can burn for, so this stove is a little bit different and has more features than I am used to having.
I definitely am not a pro with wood heat, but have managed reasonably well using it as a main source of heat. I guess im saying Hello! and I hope to learn a lot here and maybe you folks can pass on some tips or point me to the right direction in using my stove as efficiently as possible.
Ill post some photos.
I think the stove needs some reconditioning to be sure, new gaskets and such and a really solid cleaning and maybe some new paint to make it pretty again. Im not sure if the thermostat on the back works... I dont THINK that it does and we have to adjust that manually ( im used to ones that have springs that will go down as the fire gets hotter) but its otherwise in mostly solid shape.
It does need a new front handle for the door latch as the two dissimilar metals have fused to the door ( So it wont twist) , so to open the front doors we need to loosen the nut inside and pull the latch off the post. it works... when we want to roast hot dogs in there or read in front of the stove.
http://imgur.com/a/N8Spt - Image album of the stove and back information. And a cat.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
