For no good reason, today I tested the pressure relief valve on my 1000 gal storage tank, and it worked ... too well. It wouldn't seal again, and I started to lose a good stream of water out of the relief line. Fortunately, I had installed plenty of isolation valves and I was able to quickly isolate the storage tank before losing too much water. The boiler system has been in operation since the winter of 2007-8. When I removed the defunct pressure valve, the seals inside were completely shot.
This could have been a much worse situation if the valve opened due to high pressure and then failed to seal again. I also have a pressure relief valve on the boiler itself, and this summer will be the time to test that valve. Maybe the lesson learned is to test the pressure relief valves periodically to make sure they function as intended.
A ride to the local hardware store, a new 30 psi relief valve, added some replacement water to the system, and all is back to normal again.
