You can use metal tape or hi temp silcone tape both found at home depot or a plumbing shop. Did you seal with rtv silcone? and make sure all joints are twisted and locked in place? Check and be sure.
Ah, OJ Simpson Whore a Vent. It leaks more than I do after drinking a case of beer. RTV has worked for me, although some report very good results with the metal tape as noted here. Just be sure that when you do go to buy metal tape that it is rated for high temperatures. Not all metal tapes are able to handle high heat, and the glue on non-rated tape may quickly fail. The advantage of metal tape is that you can paint it, but RTV does not hold paint.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
