Those that do a LBT cleaning, do you take off the combustion fan and clean at the end of the season or does the LBT get it sparkling clean? Curious if I will need to order gaskets or not. Thx, Bubba
don't know about the fan thing but, I leave the stove door open so as not to mess up the vacuum switch during LBT.
usually take a small paint brush to the combustion fan blades and blower blades Which suffices but some here like to take the whole stove apart to get every last ash drop in the stove... to each his own....
Amazon product ASIN B074NCYC1GI found these. That price is for a 3 pack. Not sure if the englander has the standard 6" fan like the St Croix and Whitfields or not.
Eric I typically always have permitex hi-temp gasket maker on stand by to . Works just as well if not better if your fan is on the older side. Just make sure its the red hi temp stuff
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
