I have a Harman xxv pellet stove and the flame seems very lazy when the stove is cranking. Has anyone made an air adjustment on this stove? Thanks!
I just cleaned it a couple of days before xmas fine box also No I do not have an oak.Do you have an OAK (outside air kit)? When was the last time you cleaned internal exhaust passages and venting?
Edit: I always forget about the fines box on the Harmans!
Against a wall I may just try the oak. Thanks for helpWhat happens when you crack open a window? Yes, I know counter-intuitive, you're trying to heat your space. Does flame change to sluggish when you have dryer , bathroom fan or kitchen exhaust running? Sounds like it doesn't have enough air to burn well which is where the OAK comes in. Dedicated air supply just for the stove. Is your stove center of the room or near an outside wall?
Stove will be 7 tomorrow installed new gasket last year. It's always had somewhat of a lazy flame at times. Wondering if oak is the way to go. Thanks for the reply.How old is your stove? Are the rope door gaskets in good shape or have you done the dollar bill test? Just another possibility. Did it run fine before without an OAK?
Do you have any recommendations on the best OAK for the harman xxv. The stove is 7 yrs old. Thanks again.What happens when you crack open a window? Yes, I know counter-intuitive, you're trying to heat your space. Does flame change to sluggish when you have dryer , bathroom fan or kitchen exhaust running? Sounds like it doesn't have enough air to burn well which is where the OAK comes in. Dedicated air supply just for the stove. Is your stove center of the room or near an outside wall?
Stand alone Outside Air Kit ... most hardware stores carry these for pellet and wood stoves.
Just have to make sure it is the screen only style hood ... not the kind with the louvresdryer vent exhaust hood
Thanks for all your helpJust have to make sure it is the screen only style hood ... not the kind with the louvresEnsure that the fresh air intake is also below the level of the exhaust vent.
There are some interesting thimble kits that integrate the thimble opening inside a housing... page 3. Not sure of the costing though...
http://www.duravent.com/docs/product/L820_PVP_W.pdf
Thanks will do.Be careful when getting the semi-rigid flex pipe and make sure to measure your stove's inlet first to see what size it needs. Most stoves have a 2" - both of my Harmans have the 2-3/4" intakes (earlier years might be a different size). I use a dryer vent exhaust hood for the wall transition and use 3" semi-rigid flex pipe and a 2-3" band clamp for attaching to stove inlet.
