Lawn tractor blade engagement cable broke 3 times in 3 years
Stelcom66
761
Connecticut
I thought I'd post this here since many members of this forum seem to be do-it-yourselfers and are mechanically inclined. That sort of goes along with owning a wood stove and everything involved.
I have an MTD/Bolens lawn tractor I purchased new in 2006. The blade engagement lever is to the right of the seat. The cable first broke in May of 2015, again in September 2016, and again 2 weeks ago. The cable brand I installed last week is 'Genuine Parts'. I believe that's what I got the other 2 times. I wonder what could cause the frequent breaking? It's always at the part that hooks into the lever. Could it be just the OEM was of better quality? That seemed to be what the guys at the parts shop thought.
Someone on a tractor forum said they somehow fixed it, re-attached the cable onto the lever and it's been fine since. I don't know how in the world that was accomplished, but I'd consider doing something like that next time. The price for the cable has gone up every year, now with tax it's over $50. Not just the money - but it seems like these replacements are not of great quality.
Where are the cables breaking - at the very ends?
Used to have a similar problem with motorcycle cables. An old timer taught me this: look at the very end of the cable while actuating it. See if the cable flexes as the lever moves. If it does, it's just a matter of time until the cable fatigues and breaks. Lots of us would go through at least one clutch cable a year, until we modified the clutch lever so it wouldn't bend the ends of the cables. I never broke a clutch cable since. It's the little things...
That must be what mine is doing, but the lever simply pulls the cable up. The other end is attached to a spring, which is hooked into the pulley.
The person who mentioned he repaired his cable said the spring compensates for the cable being slightly shorter. Maybe the broken cable end could be put back into the lever hole, then maybe bent and secured somehow? Doubt that would work. I recall trying that the first time with no success. It seems the cable itself is strong enough, it's just the junction where the end is attached is the weak point.
Typically a crimp connection which mashes the threads of wire , if enough room solder a new connector to end of cable then use a small ring ( like those spread apart wire rings for keys) as a junction between the too. allows to flex without flexing cable back and forth. or something similar as of course I can't see exactly what you are up against. and yah those oem cable prices are insane
Reactions: Ashful
Picture would help... but im thinking the spring that pulls teh cable back to keep tension on it may not be pulling it back all the way causing the cable to kink and slowly break the strands..
I still have the broken cable, will try to get a picture here this week.
My old Crapsman had the blade lever on the right side of the dash next to the steering wheel, and a squeeze lever to unlatch the snow blade so it would angle left & right. Both of those darn cables gave me the willies over the years.
Much cheaper to get bulk cable & ferrules and make them yourself.
https://www.homedepot.com/p/Lehigh-1-16-in-Aluminum-Ferrule-and-Stop-Set-7330S-24/100239592
Yes that would be the way to go. I saw the swagging tool (that I never heard of) that Home Depot carries too.
I like this. Crimp-on ring terminal with a key ring, if space and lever design allow for it.
If replacing the cable, and assuming this is the usual cylindrical lead slug at the end type rig, make sure the slug can pivot in its hole, and that the slot the cable rides in isn't chafing against the cable (burrs).
Here's a photo of the broken cable and end. I installed the replacement but am still planning for next time. I'm thinking when, not if it'll break.
Closer shot of the end that goes into the lever. I'm thinking loop through the lever then crimped may not be a good idea due to possible chafing. I was thinking route the cable into the lever hole (where the broken end normally goes) then install a ferrul. The crimp would have to be pretty strong though.
So, that end piece should be pivoting freely in the hole in the lever. Is there something that’s causing that to hang up, and thus the cable to bend where it’s breaking?
Yes, that should move freely in the hole. I can say it did when I first installed it, but based on your thought it's something I should check again.
