Last gas chainsaw, suggestions please.
Easy Livin’ 3000
3,024
SEPA
Over the years I've had homelite, poulon, craftsman, homelite again, and currently have a small echo, small Stihl, and a husky 55cc rancher, also several corded electrics.
Battery technology has finally advanced to the point that I was willing to give a small battery powered saw a try. I was so impressed that I bought a medium battery saw in the same line, and I am also impressed with it.
I'm gonna retire the echo and Stihl gas saws, as the battery saws are so much more pleasant to use. The husky needs a new gas line, which I've done before, but I'll probably retire him as well, as its oil tank drains in storage and the fuel line issue is a well known design defect that will require replacing the lines every couple of years.
I do need a big gas saw for large trees in my lot and future arborist drop offs of big wood. Probably going up to 4 ft in diameter red oak. I was looking at the echo CS-7310P, which is their largest current saw at 73.5cc. The largest saw I've ever used was the 55cc husky, and it did the job, but it doesn't like the 3' diameter tulip poplar, and red oak that I feed it periodically.
Anyone have any recommendations for other saws in this class of saws? Having used husky, Stihl and echo, I'm open to all three, but am leaning toward the echo for it's price point and proven technology. I'm in my 50s and would like this to be my last gas chainsaw, so I'm willing to pay for something that just works and lasts. I figure if I'm lucky I'll be doing this until I'm 75, and hopefully I'll have enough wood put up by that point to retire from the chainsaw work and hand splitting!
For those who are wondering, the battery saws that I recently got are the 40 and 80 volt Atlas saws. I also replaced my gas blower, string trimmer, and long reach hedge trimmer with the Atlas versions. They are all beasts, and I'm really thrilled with them all. Won't know about their durability until I put em to the test.
Stihl MS400. I have the 362 which is a slightly smaller displacement than the 400. I don't know which one it is but I think Husqvarna makes a good saw in the 70cc class.
The MS400 weighs 2lb less than the Echo.
I have a Husqvarna 572xp (70cc class) that has been absolutely flawless for the 4.5 years I’ve owned it. I highly recommend it. It’s a joy to use, super smooth, comfortable, and fast—actually, it out-cuts my father-in-law’s big old Stihl 066 in most wood. I cut ~15 full cords of firewood a year with it, mostly red oak, sometimes larger diameter than my 28 inch bar. I run standard chain (not skip), full chisel, 28” bar, and it never bogs down. You’d be able to cut 4 ft trees with a 28” bar, coming from both sides. Just keep it sharp and the rpm’s up, and you’ll out-cut just about anything, regardless of what the stats on paper say. And it is less fatiguing than the comparable Stihl saws I’ve used.
