Large Flush Wood: Fire goes out of the box with bypass damper closed - is it okay?
yuryk
104
Eastern MA
Hi everyone!
I noticed that when I start a top-down fire in my Lopi Large Flush Wood insert or when I just add fresh logs on top (like below), I can see the fire through a small hole for the bypass rod, see video below:
I remember my installation photos and the fact that such a bypass should cover the box, so I wouldn't expect fire to get out... Unless I'm missing something or something is broken. Here are my photos during installation:
[Hearth.com] Large Flush Wood: Fire goes out of the box with bypass damper closed - is it okay?
What do you guys think? Do you have a similar situation, i.e. is this normal? Or should I worry?
Thank you!
I think you may have secondary flame above the baffle. There's no way that any little crack around that closed bypass lets through so much flame.
I think this means you're burning nice and hot and doesn't mean there is an issue there.
I would be more concerned about air sucking in through the hole you see the flames. That cools down the gases I think. But I don't know this stove well.
Hm... Today I tried with a cold start (57 degrees F in the house, we've been away), here is how it looked after 5 minutes with an open door. IMO no way the temperature is right for secondary fire in there... No idea how it happens!
I guess there is nothing I can do about that. But I must admit when it's burning. it's kind of hot in that area, so any air it might suck it very hot anyway...
Reactions: stoveliker
Oh, on this photo that white line - I guess it's bottom of the stove visible between the tubes! If so, that would explain it. Although, I don't understand why that solid ceiling is not all the way to the door like it's shown in the manual:
Hi everyone!
View attachment 332583 View attachment 332584
Thank you!
Is the the hybrid-fyre, next gen fyre, or next gen hybrid version of this insert?
Have you inspected the baffle boards and baffle insulation for damage to make sure you don't you have flames coming thru from the firebox? It looks like this iteration of the large flush has two baffle boards that sit side by side. So maybe they just need to be pushed together. Without a combustor up there you shouldn't be seeing any flames up there ever. All burning and return should be in the actual firebox and by the air tubes and not above the baffle.
  • [Hearth.com] Large Flush Wood: Fire goes out of the box with bypass damper closed - is it okay?
Thank you, I think I figured it out! When I looked from the bottom up, it's clear what happens - it's flames that go forward, then up and around the baffle - that's what I see there. See 2 pics below. So when the fire is bigger, flames go all the way into the flue. I guess it means I have a good draft :)
Exactly!
Reactions: yuryk
