We are having a bit of a cold snap here and I recently did some tweaks to my cold air setup. I think I'm getting things figured out for my situation.
Our house is a log cabin style house with a walk-out half exposed basement (see attached photo). It's a typical log cabin, very high ceilings in main area with a loft and then two individual rooms and bathroom underneath the loft area. It has no attic and only has whatever insulation which will fit in between the ~1' of space in the roof trusses. I don't feel it's very well insulated at all, as back when we used LP for our sole heat we'd use 1,300-1,500 gallons a year. We have very noticeable cold spots in a few areas in a couple rooms. To the point where there will literally be some FROST built up on the interior wall corners in those areas when it gets real cold out. The south end also has lots of glass area and two patio doors (see photo). Some windows are drafty and the front closet is not insulated (sucks pulling out a cold coat to put on in winter). It has footprint of 32'x42'. So figure 30'x40' inside. The basement is heated by the radiant heat off the Kuuma. So we are heating a 1,200sf half exposed walk-out basement, 1,200sf main area and the air space of at least another 800sf including the loft and above the main area, as the loft area has 15'+ tall ceiling. So we are probably heating an equivalent air space of a typical ~3,200sf house.
Anyway, I loaded Friday night around the typical 10pm. I waited until there were hardly any coals left as the house was plenty warm and I didn't want a lot of off-gassing, I just wanted a nice slow, low heat burn Friday night. I left the computer on low. Temps were going to start to drop Sat during the day. I re-loaded Sat morning at 10am (12 hours after the Friday night load). It was 72° in the house and 15° outside. Sat at 5:30pm I did a partial load. It was 6° outside, 77° in the house, 76° in the downstairs furnace area and 72° in the rest of the basement. It got much warmer than I thought it would. I then loaded for Sat night at 10:50pm. It was -4° outside, 76° in the house, 76° in the furnace area and 71° in the rest of the basement. I got up Sunday morning. It was -10° outside (with a -39° windchill), it was 69° in the main part of the house and 71° in the area of where the individual rooms are, 72° in the furnace area and 68° in the rest of the basement. It's now 1:30pm and it's currently -2° with -20 windchill and it's 70° in the main house, 71° in the individual bedroom area, 72° in the furnace area and 68° in the rest of the basement. It's supposed to be even colder tonight than last night.
Even letting the Kuuma eat as much as it possibly can, I'm still getting 8+ hours out of my 4cf firebox, heating a so-so insulated A-frame in sub-zero temps. The blower (on high speed and low limit currently set at 110°) never stops blowing, even towards the end of the burn, thanks to my cold air tweaks.
edit: Sunday night at 7pm. Been below zero all day with double digit negative wind chills. Currently it's -6° with a wind chill of -19°. It's 70° in the main house, 71° in the individual bedroom area, 73° in the furnace area and 68° in the rest of the basement.
![Kuuma VF100 hummin' along in sub-zero weather Kuuma VF100 hummin' along in sub-zero weather](https://www.hearth.com/talk/data/attachments/172/172249-dfd26517e5e7c75a7b72f9bdf7d6e175.jpg)
