Curious how many of you actually have your thermostat hooked up, and actually use it? Especially you guys with larger homes...and also for the same people, how often do you need to turn the burn rate (computer) up from low...and how far...ever 100%?
I have my thermostat hooked up but rarely ever use it. That being said in the recent cold snap we just had (nights 10-15 below and daytime highs in the single digits with wind) I played around with the thermostat. I set it at 70 and it worked great alternating from high /low occasionally off. I still think I like the constant low side the best. As far as the computer I leave it on low 85 % of the time. With the above temps I would set the computer up to about 1/2 way between low and medium at nite and single digits day temps would run at medium. The only time I run it on high is in coldest temps the last 2-3 hours of the burn to get the heat from the remaining coals.
Yes, a large 155 year old house. I would be lying if I said I didn't get help from the propane furnace on occasion. As stated above, running on medium in single digits during the day the house stays at about 68 which is comfortable for me. I set the propane at 67 and it might cycle on a few times an hour the last 2 hours of the burn. The same in the mornings after a sub zero nite. The 2 units work good in conjunction with each other. When the propane blower kicks in it doesn't run very long as it also blows the heat from the jacket and plenum from the wood furnace. I would guess in a average winter the Kuuma supplies about 95% of the heat.IIRC, aren't you heating a decent sized house too? That's impressive!
Nice!As stated above, running on medium in single digits during the day the house stays at about 68 which is comfortable for me. I set the propane at 67 and it might cycle on a few times an hour the last 2 hours of the burn. The same in the mornings after a sub zero nite. The 2 units work good in conjunction with each other. When the propane blower kicks in it doesn't run very long as it also blows the heat from the jacket and plenum from the wood furnace.
Nice!
I think being able to run both together, so that the fossil fueled furnace can bat clean up, so to speak, in the wee hours of the morning, or at the end of a long workday, should be the goal when people are doing a new install.
I should be able to run mine in this manner too, but I haven't actually tried it yet...need to wire in a lockout relay for the Kuuma blower to do it...honestly, for our house, its not really needed since the Kuuma will carry the load all on its own...but its nice to have options!![]()
I'll pass on a little nugget of info that I learned from Dale Friday...I've never heard this before...it needs to be in the operational instructions somewhere @lampmfg ...decals on the front, manual, website, (all) somewheres.
But Dale said that he himself just learned this from Daryl very recently...anyways, that it is important to load the wood so it is about 1" from the front face, at least on the bottom row or two...hot coals still back at least 2" away, as always...this is supposed to help get the fire started hotter/quicker/cleaner...and I have been doing this since Friday, it makes a noticeable difference, and I generally cut to 20", so its not like I was loading wood 6" away!
Just send us an e-mail and we will get you one.Thanks for the heads up, while I always keep the coals 2" back I will make sure to place the shorter pieces 1" back as I got a good buy on a full cord of seasoned 16" wood. When you mentioned decals on the front that got me thinking that I need the new Kuuma emblem on the hood of my furnace to complete my install. If lampmfg is willing to sell one they can contact me thru conversations with details.
At 8 this morning we were at 10 below, I loaded the Kuuma with three 20" splits and set the computer just slightly over medium. Now two hours later with temps at 2 below and blower on low the old house holding at a steady and comfortable 68.Yes, a large 155 year old house. I would be lying if I said I didn't get help from the propane furnace on occasion. As stated above, running on medium in single digits during the day the house stays at about 68 which is comfortable for me. I set the propane at 67 and it might cycle on a few times an hour the last 2 hours of the burn. The same in the mornings after a sub zero nite. The 2 units work good in conjunction with each other. When the propane blower kicks in it doesn't run very long as it also blows the heat from the jacket and plenum from the wood furnace. I would guess in a average winter the Kuuma supplies about 95% of the heat.
That's impressive...about the only time I can heat with 3 splits is early fall or late spring!At 8 this morning we were at 10 below, I loaded the Kuuma with three 20" splits and set the computer just slightly over medium. Now two hours later with temps at 2 below and blower on low the old house holding at a steady and comfortable 68.
