We remodeled our kitchen and it turns out to be a little cold there in the winter. The Heat runs put in aren't quite doing the job. I also think that even if more runs were put in the room would still be cold compared to the rest of the house, because we now have a 16' ceiling. Even with two ceiling fans, it doesn't stay warm for long after the heat goes off.
I have been looking at supplemental heat sources for the room and the Kuma Arctic oil stove caught my eye. Here's what I like about it: I think that if I run the Kuma all the time, on low the walls and floor would heat up, the room would feel more comfortable, and the furnace would be enough heat to make the room warm when we need it to be. The Kuma can be set to low output at 5300 btus or so, and at that rate it burns maybe 1.5 gallons of oil per day. An LP stove, as our other option (no natural gas where I live), it would be a lot more expensive to run continuously. This goes for things like gas stoves as well as wall mounted Rinnai type heaters. A wood stove is certainly cheapest to use, but it takes a lot more effort (as you all know), and the heat isn't continuous if I don't keep feeding it.
So, I think that the Kuma, running on low most of the time would take the chill off the room, and keep it more comfortable. Also, the furnace that heats the whole house would run less because the Kuma would be doing much of the work the furnace should be doing.
If anyone has a Kuma, could you tell me what the flame looks like? Does it just look like one of the burners on my stove? Is it anything resembling a wood fire?
I would like people to comment on my thoughts and tell me what you think of them. The only challenging thing is getting oil to the stove, but I think we could divert some of the oil going to our furnace, up into the kitchen, using a pump and a small tank (a few gallons in size).
Maybe running more heat into the kitchen first would make more sense, as it probably ends up being cheapest to do, and might fix the problem. The guy who did the remodel really screwed up on the heat runs. I kind of thought that at the time he was doing it, and after last winter I know it's not good. Also, I had the furnace people over to look at the kitchen and they pretty much asked me what the heck the contractor was thinking when he put in the heat runs?
Thanks for your help and wisdom.
