So here is my issue, the stupid combustion blower pulsating is making it exceptionally hard to keep a nice consistent hot fire. It goes from lazy orange dark tips to a nice hot white fire with fast tips. Has anyone found anything that helps?
ya the combustion blower pulsates from that factory by design. IT SUCKSHave you unplugged it for a few min and plugged it back in?
Ok, just thought I’d try and help however I could, most problems are caused from neglect, starting with lack of proper maintenance and or cleaning.ya the combustion blower pulsates from that factory by design. IT SUCKS
So it seems if I run it at 2lb/hr which to me seems more like 2.5 I get a nice hot fire that burns the pellets well. If i run it it anything lower I lose my flame intermittently on the ramp up of the combustion blower. If I lower the blower settings then my pot starts filling up and will spill over in less than 24 hrs. Stove is literally less than a week oldOut of my 2 stoves, the glass on my ussc gets dirty faster but it burns the pellets well
NoI have the same stove. Are you using the wall mount thermostat?
I have five heat levels. You set high and low and the middle three are figured linearly. US Stove states that I need to have a 3’ vertical rise to have this stove vent properlyMine also pulls the flame down quite a bit when the motor pulses.
You mentioned setting it at 2pph. Can you elaborate on how you set this?
Also, how many heat levels does yours have? Mine has 3. When adjusting the PPH feed rate on mine, the process is to set the low (PR1 feed rate) and then set the high (PR3 for me) feed rate. Then the levels in between are figured by the board. I have mine set for 1.6pph on PR1 and 5pph on PR3.
An overflowing fire pot does point to an air flow issue. Have you made any adjustments to the draft low and high settings?
I also have mine set to run off a room thermostat. This means I try to set my PR1 pph/draft setting very low so it is almost just a pilot lite. Then when the thermostat calls for heat the stove kicks up to PR2 or PR3 depending on where I have it set at.
If I was not using a thermostat I would probably set my PR1 heat output slightly higher so it would be more usable.
Have you looked at the USSC Troubleshooting sticky thread at the top. In that thread there are a lot of Technical manuals available that help explain all the different settings that you can adjust and tell how to do it.
Re-read. looks like you have messed with the draft speed.I have five heat levels. You set high and low and the middle three are figured linearly. US Stove states that I need to have a 3’ vertical rise to have this stove vent properly
So your saying you set your low as basically a pilot until the thermo calls for heat then it ramps and work better?Re-read. looks like you have messed with the draft speed.
I will say that my flame is sucked down considerably when the draft motor pulses on and on my pilot light setting (PR1) the flame can be very low when the draft pulls.
On PR1 my flame can also vary drastically as the agitator turns. Sometimes it can simply look like a bed of red coals temporarily until the agitator turns some more.
The more I messed with the settings on mine the worse it got. I did a reset to factory settings and it works fine. It really heats well. I leave draft and room fans set on "A" (automatic)Yes the fan pulses and takes some getting use to. It does burn a little rich on setting 1 but not on on 2. I've never had the need to go above 2. I tried the wall thermostat and it didn't work well for me.
