Ok I just installed the King Pellet Stove 5502M from TSC in the beginning of December. Here are a few pics of how it is currently setup.
Ok, now some background. It was not my idea to get a pellet stove, nor was I invovled with the installation or past usage, until now. "She" who must not be named set this all up, with a contractor friend installing it. I assumed that she understood what was required to run the pellet stove efficiently and safely. Never assume with women!
It wasn't until I decided to clean the stove because I found the glass window blacked out and my ADHD kicked in. I immediately found a problem when I opened the door.....
The amount of ash was unreal, and this is only after 2 weeks since "her" last cleaning. She said you just scoop it out...
I cleaned it out, and tried to have a conversation about it, but was overruled and stove was restarted without changing anything. Now today 7 days later, I opened it up again, not nearly as much ash but still enough to be pouring out when I opened the door. So I decided to step in.
Normally the HR is on 1-2 and everything else was on Auto, I believe. I have never seen a flame burning inside the stove, but it has always produced heat and never any ERs, albeit more than likely not efficiently.
Now the little research I have done today says the Draft Fan should be 1-2 pts above the Heat Rating setting. So HR 2 is a DF 3-4. Adjust these settings I can start to get a flame I believe should be normal, healthy and dancing. However I think there is an underling issue.
The Room Fan is extremely loud, and drowns out what I believe is the draft fan I should be hearing. Because the 2nd much quieter fan is intermittent at best. It sounds like its trying to blow for 3-5 seconds and then its not for 5-10 secs, and then it tries again and then its not.
This is obviously causing problems with my flame, for moments it is great and then its getting smothered.
One thing I did not clean out was the exhaust fan, and there is no intake pipe. I am assuming this fan struggling to run is not normal and is causing some issues?
Is this all related to the ash buildup too? Or is that related to terrible settings?
Thanks for the help in advance!
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173797-ad6eb7a1b2add6e727d63bc8edfa95c6.jpg)
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173798-317cfa2f73e16d32577bd2fbb0cf93d3.jpg)
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173799-e8ad2e918fdadce62f5d8c8f57248911.jpg)
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173800-c0db8650baa778d4cf1da5452cee9154.jpg)
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173801-ebfef296dbc1aa79eefa3c234fbdb85d.jpg)
![King Pellet Stove 5502M - Issues King Pellet Stove 5502M - Issues](https://www.hearth.com/talk/data/attachments/173/173802-2c7bb85e0fd72f595bddd1c9d053fe9b.jpg)
