Knowing me I'd ram that in my leg on the first trip out, then stab my cutting buddy in the eye as I pulled it out and screamed. I'm not all that coordinated.![]()
You best just stick with a chainsaw. This little piece of fiberglass with a magnet on one end is dangerous.
Just measure your saw and bar,add a mark at the lenght you cut then you have a measuring tool with you at all times
If you are going down the log marking then there is no way that it is faster,you are making 2 trips down the log.Much slower and not near as accurate that way Ive tried it. This thing attaches towards the end of your bar and then you go down the log sawing an inch or so deep and move to the next mark. You can mark a whole log accurately in seconds. Move to the right or put it on the other side of the bar and move to the left either way. Super simple.
Ive done this, and it works, but even better is the 18” long stick I carry with me when cutting. I run down the trunk of the tree, measuring off 19” lengths with my top handle saw or the kids’ driveway chalk in one hand, and that stick in the other. Then I grab the 064 and buck on those marks. Perfect 19” rounds, all day long.
I masked my stick with a corkscrew of blue painters tape, and shot it with fluorescent orange spray paint. Once the tape was removed, it had bright orange stripes. Now I never lose it in the woods. I’ve since done the same with my Logrite cant hook and hammer.
An inch too long is no problem with your cavernous boiler. A small stove is a different story. Accuracy makes for a much better experience in a small firebox. Mine fits 16", and I kept running into peices that were just slightly long, not a pleasure when trying to pack a hot stove. I now measure for 15.5" to minimize those special moments.If you are going down the log marking then there is no way that it is faster,you are making 2 trips down the log.
With the lenght marked on the saw,cut a lenght step over as you are moving sideways set the saw on the log as you step and when you have your new footing the lenght is there for you to cut,cut step repeat,cut step repeat...
Besides this is firewood we are talking about,it will be burnt.No need for accurate lenght.
My saws are marked for 20" wood,my boiler can fit up to 26" wood in the right spot,accurate lenght of firewood is not a priority for me.When i go salvage fire-smart wood( wood that has been cut already but is in the bush from clearing to prevent forest fires around town) it is random lenght,everything from 10" to 24"+. Keeps the house as warm as perfectly cut 20" wood.
I don’t mind handling my stick. [emoji14]Instead of having to handle your stick and spray paint a mark you put your stick on your saw and mark it with your saw.
i use these as well...they used to be available in 16,18,and 20 in with the wheel being adjustable on the 20 in model..I use mine every time I hit the timber to cut...we will grab a smaller saw and start marking logs while someone starts sawing rounds up.Much slower and not near as accurate that way Ive tried it. This thing attaches towards the end of your bar and then you go down the log sawing an inch or so deep and move to the next mark. You can mark a whole log accurately in seconds. Move to the right or put it on the other side of the bar and move to the left either way. Super simple.
I used the marking stick same as you before I tried this gizmo. This thing is like your using your marking stick only much quicker and easier. Instead of having to handle your stick and spray paint a mark you put your stick on your saw and mark it with your saw. Sorta like using your marking stick only attached to your saw. When you get to the end of the log pop it in your back pocket and cut your way back to the other end of the log. You can also paint it however you like.
Its well worth the little time it takes to cut accurately. Much much better.
Same here...I finished up last year cutting to size stuff left over from the boiler days...what a pain.I won’t even take free wood anymore, if it’s been cut to random or the wrong length. Anytime a buddy asks me if I want wood, I tell them, “only if you leave it in log lengths.”
