Running the Keystone this afternoon while watching some football and I've got it cranking.
550 stove top, 310ish stack temp and a 97 percent clean glass - YIPPIE!
Beautiful flames across the firebox rolling up from the logs and wicking the bottom of the cat shield. Also, at these higher temps, I've got a goodly amount of active cat going. Anyone else seeing an active cat, at high temp burns without the damper turned down?
No visible smoke out the chimney - amazing. For the first time, my neighbor's chimney isn't spewing smoke either - he must have let the fire go out....
One thing about pluging the ash pan hole is that my burn is now totally burning from front to back. As the front logs start to clapse as they burn down, they reveal the logs stacked at the back of the stove - still looking pretty solid. My guess is that the hole in the back of the ash pan housing feeds the fire for these back logs for a more even burn across the bottom of the stove. This additional air may yield more btu's, but for now, I like the burn front to back and knowing I have apparent total control of the air coming into the stove and all of the incoming air washing across the front of the glass.
Bill
Bill
