I ordered a new catalyist combuster for my Keystone today. It is under warranty and the only charge is shipping - yippie & horray for Woodstock customer service!!
We have been in a semi-shoulder season around here for about 6 weeks, sometimes temps dipping in the 30's and lower 40's, but warming-up nicely during the afternoon and have only been burning the Keystone to knock off the chill and even then go for days with no fire.
When building these shoulder season fires, we have been turning the damper down for a smaller cat only driven heat vs full flames and glowing cat. We noticed that the combuster was not lighting off very well and not glowing at all (I know it doesn't have to glow to be working). I talked to Woodstock, they said to vacuum/brush it off and see how it does. Did that, burned it for another couple of weeks watching the combuster, stove top temps and visible smoke coming out of the chimney. Also noticed the cat crumbled a bit when I lightly brushed it off - not good.
This weekend was a bit chilly, and since I was home for both days, I had a good opportunity to check the cat a little closer. Sure enough, smoke out the chimney, no orange - no matter the damper settings and stove top temps not making it over 400 degrees - flames or no flames.
Bottom line - cat combuster is not working, so I called Woodstock today and a new cat is on the way.
We are about done for the year for burning, but it will be good to get a new cat in place for next fall.
BTW, the new combustor will be the stainless steel model.
Thanks!
Bill
Thanks!
Bill
