Kerosone fuel for a jet heater - not that easy to find these days
peakbagger
8,979
Northern NH
I have 30 year 100K jet heater that I use on occasion. The last time I filled my tank was easily 20 years ago so it doesn't get used often but sometimes its quite handy. I went to use my snowblower yesterday and found that the impeller was frozen solid to the drum in pretty big lump of clear ice. I tried chipping it but at around zero degrees I wasn't in the mood for a long effort. I tilted the snowblower chute up and got out my jet heater and aimed in in the chute. About minutes later it was melted out and I was out snowblowing. The bummer is 20 years ago there were a couple of places in the area that sold kerosene at the pump but no longer. The local Irving gas station used sell 5 gallon pails for truckers to dose their fuel if it got suddenly cold but they don't carry it anymore. If I want a 100 gallon minimum and have a bulk tank I can special order it but not practical for my usage. Right now my only option seems to be a special order 5 gallon can from Ace Hardware at around $10 a gallon. Plenty of places sell the equipment but looks like few sell the fuel.
So any suggestions I am overlooking for finding and buying K-1? I have heard that winter diesel I pretty close to kerosene and now that its ultra low sulfur do I just run winter diesel?
I switched to propane fired heaters. My kero units got too pricy, and running Diesel isn't that much better on the pocket book. that said I was using #1 fuel oil in areas where the left over scent wasn't going to be a problem.
Searching around after I posted this I see a lot of references to using Jet A and many folks are using #1 Diesel. My guess is Jet A and K1 may be straight run distillations so they will be more stable if the stuff sits in the heater for years. My guess is regular diesel is probably at least partially cracked so it may have shorter shelf life although rarely do I hear about shelf life issues with Diesel.
Around here, you can find it at gas stations in the ghetto type areas. They still use it to heat their homes.
Might want to call a fuel supplier and see if they deliver it to anybody.
Reactions: fbelec
Kerosene is available here at many stations.
Local station here carries kerosene . . . not that it helps you any, but perhaps if you start looking at the independent gas station vs. chains you might have more luck.
Any home heating oil supplier should have it. A few stations around here still have it.
I wish it was so simple. The local gas stations are chains and they do not have Kerosene pumps and the same with the heating oil dealers.They will do bulk deliveries but that is it. It strange as lot of folks used to use kerosuns.
Jet A and Jet A-1 are both blends, like gasoline is a blend. The main difference between A and A-1 is the freezing point. The base hydrocarbon mix to make Jet A/A-1 is kerosene.
I have one of those Diesel smoke heaters, but Iv since converted to propane powered torpedo heaters and propane radiant heaters. Mostly because of the obnoxious smell but also because of the availability of fuel. Which i think is called "white " kerosene around here. Very hard to find nowadays.
My propane / fuel oil dealer has a kerosene pump at his bulk terminal.
No problem getting kerosene from him, but winterized off road diesel fuel is cleaner since they took the sulfur out.
The off road diesel is the same product as number 2 fuel oil now a days, and is the same as on highway diesel, with the exception that the on highway fuel doesn’t have the red dye.
Most modern torpedo heaters are rated for either kerosene or diesel fuel.
Same here, but expensive. I remember when Kero was the cheapest red headed step child fuel around, now more than gas.
fuel oil dealer here as well. colonial oil here in chelmsford sells from the pump off road diesel low sulfer diesel kerosine gasoline and propane
