Greetings; Been gone for awhile - so haven't used my RA 2490 in about 5 years. Bought it used - knew (know) next to nothing about wood stoves. So trying to get it working this year I find I am having issues with air control and getting a fire going. wood I am 'trying' to burn has been split and stacked for 5 years - if it ain't dry now - it never will be! Am wondering if I should put the time/$/effort into repairing this stove or if I should cut my losses and look for a new stove. Am trying to heat an 1100 sq. ft manufactured home that is pretty well insulated. Here's what's up with the stove in its current condition:
1) very small crack in the glass at the very edge.
2) combustion package has certainly seen better days - holes at the bottom are 'worn away'; was going to post a photo - but don't want to take out the rear fire bricks again cuz:
3) rear fire bricks: one is cracked and missing a small piece of the brick at the center edge - not sure how much this matters
4) cracks in the L and R fire bricks; one is very close to falling apart
5) air control valve (name?; lever at the bottom of the stove) does not seem to be operating. I can't keep a fire lit w/o the air controller in the 'start' (full right) position all the time, and even then it's tough.
6) minor, minor smoke leak somewhere, only noticeable after a few hours of burn time - possibly only common gasket replacements but maybe full breakdown and reseal?? 'smoke test' revealed nothing; light in the stove in a dark room shows no 'leaks'.
Quite frankly - I don't have the time, energy or interest in rebuilding this stove or troubleshooting it. Unless you think a few tweaks might be all it needs. I'm in the middle of a house overhaul that really needs all of my time and energy. I 'might' be able to find someone local to do it for me if you think it's more cost effective - tough call - I realize.
IF I opt to replace it - recommendations for a suitable, somewhat inexpensive stove that could also heat a 1400 sq ft house - as I'll likely take the stove with me when I move in a year or two.
thanks for your time and input
Kelly
9000 ft Colorado (hopefully moving to 7000-8000 ft, and a little farther south, in the future)
Kelly
