Just cleaned up the rust on my Empress
srjtr7
71
Near Boston
When I went to clean my Empress for the first time. (I had it installed last year) I had rust inside.
Many people gave me suggestions here on what to do. I decided to clean, sand, scrape and paint.
I used Hi temp stove paint that I got from the pellet stove place that I bought my stove from.
I know for the first few times I run the stove it will stink.
How do you think I did?
Will this protect it from rust?
Will the paint just burn off?
Here it is before.
[Hearth.com] Just cleaned up the rust on my Empress
During cleanup
After
Excellent job! I just did the same to my Castile with the same results. I don't think the paint will last long in the those areas with a lot of flame contact, but I've burned mine quite a few times and a still looks great.
Don't take my advice, I waited a few hours and thought it would 'cure' quicker with a little heat. Ended up re-doing the sides. A day or so probably should be fine I would think. Fire sure looks pretty now with a black background. For looks and good maint imho.
I only had my stove for one year and it was rusting and looked bad to me. I might have put 15 bags through it.
I did it so 1. it would look good. and 2. so that I could make sure the stove last as long as possible and does not rust out.
Not that I mind doing it.....but I wish they told me about this when I bought it.
I allready fire it up.
I let the panels sit in the sun for a few hours. Installed them waited a few hours and then started it on low for a hour.
Then medium for 2 hours.
I will take it apart tommorow and see if any of the paint looks different.
