Actually the baffle appears to be fine but it fell off the rear wall of the stove and landed in the firebox. I'm trying to figure out how the baffle was attached to the rear interior wall. I can see the bolts/screws and nuts that match up to the mounting holes in the baffle but they don't appear long enough to attach it back on. Could the bolts have sheared off or was the mounting area of the baffle extremely thin? It almost appears that the bolts had a nut that attached them to the rear wall and then extended out into the firebox so you could slide the baffle on and then attach a second nut (and maybe a washer). Could that be true and if so, how do I get to the bolts so I can replace them with longer ones that will again reach thru the baffle? Thanks in advance for any help.
