Jotul Rangeley overnite burn
CapeCodder
19
Eastham, Ma
My new Jotul Rangely is all seasoned and I am disappointed that I can’t get an all nite burn...I would like to load it at 10 pm and keep it burning till 7am...but it runs out of wood around 2 am or so...suggestions?
Dug8498
259
Southern NH
I'm not familiar with the stove but I'd be curious to know what kind of wood you're burning and how dry the wood is?
Dug8498
259
Southern NH
I am mostly burning oak that has seasoned for a year...
May be something to look at. I'm in southern NH so the weather here is pretty similar to where you are I'd imagine. I know there'd no way I could season oak in 1 year here unless it was pretty dry to begin with. If you have a moisture meter you can split a couple pieces open and test the moisture content to be sure.
Bad LP
877
Northern Maine
I don't see it happening myself. My insert is larger than the Rangley and will not burn thru the night but I do still have hot enough coals in the morning to relight with just a small amount of kindling. My wood is under 16% measured on a fresh split. Mostly maple and ash with some birch.
weatherguy
5,360
Central Mass
How long is your flue?
bholler
Chimney sweep
Staff member
Jan 14, 2014
18,638
central pa
Tell us about your setup and burning procedure. The rangely is a decent sized stove you should be able to run overnight on oak.
sutphenj
Burning Hunk
Nov 19, 2010
160
West MI
I have an f55 (similar to rangley) and you wont have flames in the morning. 200-300 STT after 8 hours yes but no flames.
firefighterjake
18,901
Unity/Bangor, Maine
My thinking (which is par for the course this time of year with folks new to using a modern woodstove) is either . . .
a) they are thinking there should be active flames for a solid 8 or 9 hours (least aways that's what I expected to see when I read about the "burn" time) whereas there is plenty of heat being produced during the coaling stage
or
b) they are running the woodstove with the air control open all the way which eats up wood quickly.
Letting us know how you run the stove will help.
7acres
647
South East USA
1yr oak is not optimal. I'll get 10hr burns consistently with 2 or 3yr seasoned oak in my F55.
Ludlow
1,082
PA
My brother always saves the fattest half splits for overnighters. Better to have 3 fatties than 5 or 6 smaller splits.
bholler
Chimney sweep
Staff member
Jan 14, 2014
18,638
central pa
I disagree with that. I always get longer burns packing as much wood as i can in the stove which means a big one or two then fill all of the spaces with small stuff.
Ludlow
1,082
PA
Ok. You jam it. I get it.
I know he puts some REALLY big logs in there. I know because when I was running the splitter he yelled at me to leave them giants alone for overnighters. Maybe he jams sticks in the holes too. Probably.... I have never been there overnight to have witnessed.
My point is he uses the larger LARGER splits.
Reactions: bholler
bholler
Chimney sweep
Staff member
Jan 14, 2014
18,638
central pa
To each their own. I dont like doing it that way but that by no means makes it wrong
Ludlow
1,082
PA
Would not the drier wood burn faster though?
bholler
Chimney sweep
Staff member
Jan 14, 2014
18,638
central pa
No because to make it burn at first you will have the air open pretty far then you go to bed and it dries out. Then it takes off and burns fast. Wet wood is no good for anything.
Reactions: Woody Stover
begreen
Mooderator
Staff member
Nov 18, 2005
78,577
South Puget Sound, WA
How close can you load it to the baffle? Almost touching?
A bit over the top of the firebricks should be sufficient. It shouldn't hard up against the secondary baffle. I suspect that the wood is not fully seasoned and takes too much air to get going.
mcstatz5829
147
Indianapolis
Great, that’s what I did last night and it worked great.
It could be wet wood, but it could be inexperience with the air controls and loading. My first attempts at overnight burns were unimpressive. Last night I finally got a load to go a full 8 hours. Had a very nice bed of coals when I woke up.
BIGChrisNH
372
New Hampshire
For a tube stove, a good bed of coals is best case for the morning re load. I know I never have live flames in the morning, but always a good coal bed, from 10pm to 7am, roughly.
7acres
647
South East USA
7acres
647
South East USA
Oh, got it. Stove top temp will be around 400F. There is a big bed of large coals at the 8h mark.
