- May 16, 2007
- 59
I think we have narrowed our fireplace insert choice down to the jotul kennebec. The local dealer has a display model that he will knock 20% off... seems fair and the installation quote is in line with what I see here.
A couple of questions - okay more than a couple...![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
1. With the insert mounted flush - I will have 16 inches of hearth in front of the glass (it projects 2.5 inches onto hearth). The manual states that 18 inches in required. I have read here that u.s. code is 16 inches and canadian code is 18 inches. Since I am in the u.s. I am thinking that 16 inch clearance is sufficient and I can safely ignor the manual? right? Or should I take the time to extend the hearth?
2. The stove can be mounted protruding outward about 7 inches (from flush). This seems advantageous in terms of heat output - convective air flow. But I would have to extend my hearth. I noticed most in the photo gallery had theirs mounted flush and it looked really nice - my thoughts are that having it "out" will detract from the cast iron look of the fronts - any thoughts?
3. I want it to pull outside air for the combustion air supply. You can run 3" flex off back of stove for this. For outside air supply should I have them run flex up to the chimney cap or drill a hole in the masonry? Any advantages or disadvantages to either option?
4. The surround has "jotul" stamped on it, but the ones I see in the photo gallery are plain. I am thinking the jotul stamped one is for "floor display" and I should ask for a "production one". Sound right?
thanks,
jeff
thanks,
jeff
