I inherited my dad's old place with a Jotul Firelight 12 in it, with a short horizontal stub of a flue connector before it disappears into the wall and into a 30' tall double walled, boxed-in chimney pipe. He must've always had a hard time getting dry enough wood, because I never saw him able to operate it without the ash door open. When I took over, I wanted to be able to get off the oil furnace completely, and just use the stove, but also found I always needed to keep the ash door open. I took the rear burn plate off and found no catalytic converter, and some refractory blanket missing. I then discovered there was no fresh air feed designed to the grate via the ash box, only the air wash down the doors, so I cut two additional holes in the stove floor directly below the existing holes at the fresh air slider, which lead to the ash box, and engineered a couple of extra doors for those on the slider. Everything worked great after that, but I'm wondering if I can further modify the stove to optimize secondary burn without a cat. The secondary burn setup on the F600 looks great, but not sure how best to incorporate something like that into the Firelight 12. Any feedback would be welcome. I've included some pics of the air feed mod.
![Jotul Firelight 12 Modifications Jotul Firelight 12 Modifications](https://www.hearth.com/talk/data/attachments/293/293136-13a5a6205b17e71c05212f705ace6396.jpg)
![Jotul Firelight 12 Modifications Jotul Firelight 12 Modifications](https://www.hearth.com/talk/data/attachments/293/293137-d96f3d494125a1c5fa6588f3dd24d401.jpg)
![Jotul Firelight 12 Modifications Jotul Firelight 12 Modifications](https://www.hearth.com/talk/data/attachments/293/293138-e984e20c20c23ec30a44243115ca5526.jpg)
![Jotul Firelight 12 Modifications Jotul Firelight 12 Modifications](https://www.hearth.com/talk/data/attachments/293/293139-e775f8d50477a7a2123de86fdbd09a56.jpg)
