I recently found that I have damaged the right side manifold on the burn tube assembly. I'm guessing this happened when I fell asleep after starting, with the side door cracked open.
My local stove guy sells individual parts so I can buy just the right side (door) manifold, but I don't know how the tubes connect into the manifold, or how you would determine if the tubes need replacing.
I did find this old thread that says you should replace the whole assembly--but not too much explanation for that claim:
https://www.hearth.com/talk/threads...ul-f600-firelight-inside-guts-of-stove.76480/
Anyone know how if replacing the single part makes sense, or how to do so, and whether or not I would be better buying the whole thing as a unit? (It is expensive--I see it on Rocky Mountain stoves for $240, vs the $35 or so for one side.)
Dean
Dean
