Jotul F500 V3 Oslo install
May 18, 2013
85
NC
We've been burning an old VC DW Sequioa for over twenty years, now deciding to upgrade to Jotul. Any Install issues to be aware of? Will it basically be a "plug & play"?
Reactions: Todd
Also, any suggestions on how to move it from the driveway, where it'll be dropped, to our raised hearth up four front steps and into the house?
The new stove may be much more picky with wood: it needs to be dry. Do you have a moisture meter?
How tall is your flue?
There are "stair dollies" that can move things up stairs.
Wheels help.
I used two cheap furniture dollies on my level trip from the driveway thru the garage into the basement.
Thanks for reply. Yes, use a mositure meter all the time. Flue/chimney is 20' tall. Thinking about dollies...thinking
maybe hire a couple moving guys? Still thinking...someone mentioned chimney sweeps should be able to move and install?
thinking...
It is likely that the system should be fairly plug and play with a 20 ft flue.
I would suggest to have it inspected for integrity.
Is it lined and insulated? (For safety and code compliance, unless you have 2" of clearance from the brick to combustibles for an inside chimney, or 1" for an outside chimney.)
Are you going to meet clearance with the stove?
Do you have enough floor protection in front of the stove?
The stove sits on a raise hearth, 18" above the floor, and sits just inside a masonary fireplace metal lined. The chimney has a stainless steel liner in place (which was just cleaned). There is a fire retardant rug in front on the floor.
I'm not sure the rug is sufficient - but my knowledge doesn't go that far.
The rest sounds good.
It'd be best if the liner is insulated; stoves work better that way, it's safer, and code/insurance like it better.
If the fireplace in which it sits is on an outside wall, do you have rockwool insulation behind the metal? Otherwise you'd loose quite some heat that radiates out into the masonry and which then radiates out to the great outdoors.
Do you have a (sealed and insulated) block-off plate? That helps a lot preventing cold air coming down next to the liner when the stove is not in use, and heat going up when it is.
