We have a jotul f500 that was installed in our camp in Maine in 2000 , my parents have spent the summers there for the past 20 years and only use the stove to take the chill off of the house in the morning’s and the evenings ,so the stove has never been run as it was intended too . The past couple of years I’ve been spending a few days there in late October and have been trying to get a long burn but can only get a couple of hours out of it , the primary air control slows the flames slightly, but know where near the lazy flame that I get from my f400 that I have at my own home in Ct , there is no secondary burn as well . I’ve checked the doors and ash pan gaskets for leaks , as well as doing a smoke test to look for leaks in the stove it’s self , when doing the smoke test I’ve noticed the only place that air is drawing in is through the secondary air inlet in the rear of the stove . After trying different species and size of wood and not getting different results I plugged the secondary air inlet with tin foil and the stove acted like my f400 a very lazy flame with a secondary burn coming from the tubes on the top of the stove. I’m trying to figure out what I have to do to fix this stove properly as it wasn’t intended to run with the secondary air inlet blocked . Just a little info ,the chimney is 8’ of double wall inside the house transitioning to 12” of triple wall outside, and the stove was purchased in 2000.
thanks ,
Eric
thanks ,
Eric
