I meant to do this years ago, but better late than never. I have lots of pics so will do it in a few sections.
I found a "like new" Jotul f400 about 5 hours away near Boston in 2019. I paid $1,600 for this Blue/Black enamel version. At the time a similar f400 new was over 3K and a multi week wait. This stove did turn out to be in Great condition.
I had my wife's Honda crv and our dog to get the job done. The seller was a nice lady who helped me clean the inside and roll it on a dolly thru her house and onto the back deck. She had an older shop vac that she lent me to vac out every bit of ash and soot in the stove. There was not much but enough was stuck to the walls and baffle to make a soot mess if not vacuumed out. I cleaned it to be pristine, in about 10 minutes.
Step 1. Put drop cloths all around to contain mess and have space to put pieces.
2. Disconnect stove from stovepipe. This Was already done.
2A. Lift off Ash lip and put in Box.
3. Remove back top/rear vent adapter (2 bolts) Put in carboard box with gaskets and the 2 bolts.
3A. Remove large piece on back of stove, that vent adapter bolted onto. Put in box. (This may be step 4 or 5 i just dont remember?)
4. Reach in and lift deflector plate up and out. No screws, it just sits in the slot. Put in a small cardboard box.
5. Located 2 "shipping bolts" on right and left side that hold down top. Unbolt (i did not reuse these, they are better left off for easier cleaning of the stove in the future) Lift off Top and put in a box, top down to preserve gasket.
6. Remove door. Lift off and put in a box. Be careful, i left the handle on. Padding is a help with this box.
Now is a good time to take boxes outside and put in safe place. Clean up drop cloths. Carefully lift stove one side at a time onto a dolly. Roll stove outside slowly.
7. Now outside you can use a leaf blower to blow out the inside. Then you can shop vac it.
8. Lift off top baffle plate. Slide angle brackets that hold it tight to free it. Put in a Box along with gaskets.
9. Remove inner plates both sides and back (lift them out). Put each in a box.
10. Mark position and Remove firebricks from behind back plate. Be very careful these are delicate and keep in order and front and back and top and bottom. They are tight to refit and go back in best as they were in before.
11. Remove ash pan and put in box.
12. Remove Ash Grate, put in box.
Part 1 Done
![C98B2957-574C-4EE1-87D7-64DDE1CEC4B2.jpeg C98B2957-574C-4EE1-87D7-64DDE1CEC4B2.jpeg](https://www.hearth.com/talk/data/attachments/297/297262-b99c856b8c28f5dbb52cde7c9b20e75f.jpg)
Part 1 Done
![B752F658-B6A6-4101-A9EA-9613B430DB89.jpeg B752F658-B6A6-4101-A9EA-9613B430DB89.jpeg](https://www.hearth.com/talk/data/attachments/297/297255-08f43867f6627e41a3a26430977929e2.jpg)
![2F8AF634-2E99-4FAD-BA61-1E6B8343C072.jpeg 2F8AF634-2E99-4FAD-BA61-1E6B8343C072.jpeg](https://www.hearth.com/talk/data/attachments/297/297259-ac0670907e1df2297a0795f63d4450a6.jpg)
![51F30B55-E11F-40DD-BBC9-7BD1C4DB2845.jpeg 51F30B55-E11F-40DD-BBC9-7BD1C4DB2845.jpeg](https://www.hearth.com/talk/data/attachments/297/297260-7c33b41366da79c1e44e96789f8a4922.jpg)
