Ok, I figured I'd put an appropriate title on this one. As I mentioned in another post, I've put a deposit down on an F3CB and should be getting it in a week or so.
I had a panic attack yesterday when I realized I hadn't actually measured the space inside my chimney. The F3CB calls for a 6" flue, which in most instances results in a 6.25" OD. Adding to that 1/2" insulation and it comes up around 7.25" OD. I had been figuring I had enough space but....got the folding ruler out this morning and I've got 9-5/8" across the narrow dimension. PHEWWW The cement that squeezed out from between the bricks isn't too bad either so it shouldn't snag the liner very much as it is installed! Thankfully, I'm good there.
Reading the manual it looks like the proper stove pipe to use at the stove is single-wall, correct?
My chimney is an interior one and my flue is going to be roughly 23-24 feet tall with the stove venting from the rear. Looking at it, there will roughly be 16 inches between the stove and the tee with a slight upward angle. With that length of flue should I be on the lookout for over-drafting?
For the F3CB, what is the best length of firewood? Jotul states 18", but is there enough room to easily use that length of wood? Seems I've read where a shorter split works better.
I'm still debating on a liner kit. Currently looking at the Flex King Pro and the Rockford Deluxe Smooth Wall. I see that Rockford has an option for a "standard" flex liner that is $135 than the smooth wall. I'm thinking that the smoother wall might be worth the added premium. Any thoughts shared on these liners are appreciated.
Liner installation...top or bottom? Yelp, I've read several threads. My lintel is only 27" high so I'm thinking installing from the bottom might be a bit ornery...but, shoving a 25" piece of ss pipe down from up top doesn't seem to appealing, either. I've got a painted metal roof on my house...it seems the wire mesh wrapped liner could possibly scratch up the paint. Thoughts?
Durock...I read a while back where it had be de-listed (or whatever) for use in building a hearth board. What can be used in it's place?
Thanks for the help....wood burning is coming closer to becoming a reality!
Ed
Ed
