In anticipation of an F3CB in the near future, I am trying to determine the distance stove will need to be from wall when installed in a corner (at 45 degree angle). Entire floor will be noncombustible tile/stone so I am assuming pad size not an issue.
I plan on installing a stone veneer in corner all the way up to ceiling and after looking at Jotul manual online, I still can't determine what's right. Is a stone veneer same as a wall shield? How far must back corners of stove be from wall? Will there be a difference in clearances if veneer is mounted to sheetrock as opposed to concrete board? And, how far must veneer extend past front corners of stove? In addition, 30inches from corner of room and 30inches up from floor is the bottom corner of a window. Corner of window is just barely visible on left side of this picture.
![Jotul F3CB corner clearances Jotul F3CB corner clearances](https://www.hearth.com/talk/data/attachments/223/223548-8b5faae97223cff28d5600efaac35a98.jpg)
If you have the patience, your help is greatly appreciated.
Thx!
Thx!
