Greetings,
Long time lurker, first time poster here. Ive been able to find about everything I need through searches, except this one issue. I have a two story house from the 70's, attached garage off to the side is one story, with one side of ridge line being garage, and the other, back side being living room. In my diagram x lines are two story, - lines are single. I want to install my stove in the corner where the o is.
This gives me two issues. first is will I have drafting issues with the stove being that close to two story structure, and second, will i have issues not being close to the peak of the roof for the garage section? Chimney height will be 15', minimum specified by Jotul and it will meet my clearances required on roof.
Edit: Forum program keeps modifying my diagram when i publish it :/
Basically i want to install stove in the back right corner of single story living room portion, along the two exterior walls where roof will be at its lowest, as opposed to being more centered near peak
xxxxxxxxxxxxxxxxxxxx-------------------/
x x o /
x x /
x--------------------------x------------------/
x x \
x x /
x x o /
x x /
x x \
x x /
