New homeowner. I have an existing fireplace that I've been told was originally a coal-burner, thus very small dimensions. The firebox is 24h x 24w x 13d. The surround is 8". The hearth is 40w x 31d. The chimney is lined with stainless steel.
I'm considering my options for putting a wood stove on the hearth as a supplemental heating source. Small house around 1000 sqft first floor, 400 second floor. Fireplace is in the middle of the first floor right by the stairway.
I'm planning to redo the facade so I want to know how much higher/wider I'd need to go with non-combustibles in order for the clearances to be safe.
So my questions are:
- Based on the manual (pg 12), I need to raise the top surround at least 9" before combustibles to equal 17" correct? Blue tape in photo two.
- I don't have much side trim clearance (8") and the manual calls for 14". If I simply remove the trim on the sides, does that take care of it? Or do I need to increase the sides surrounds out 14" before the drywall?
- If I redo the surround and have it protrude from the drywall with no trim, does that satisfy my clearance issues?
- Can I have the back of the stove tucked up close to the firebox like this? Rear exit connection. Pretty sure I would need to increase the hearth depth if I can't...
The manual
(broken link removed to http://jotul.com/us/products/stoves/_attachment/7440?_download=true&_ts=13b910774c5)
Photo one is a straight on view of the fireplace when we bought the house, it hadn't been used in a long time and had some foam insulation covering the opening.
Photo two is a side view with a dummy F100 in place to see how big it would be. The box depth of 17.5" includes the ash lip so I think the depth is really only 14.5-15" I have torn off the tile in preparation for redoing the facade.
The manual
