Hi all! I am getting ready to install my Jotul F100, and I have some questions regarding a few details and clearances.
First question concerns the hearth pad. I plan to have a local metal guy make a steel hearth plate to the required size as listed in the owners manual/installation instructions. Manual states that "any noncombustible material with use of the bottom heat shield" may be used. The metal hearth plate will sit right on top of the laminate wood floor. The manual seems to be okay with this. Do I have that right?
Next question concerns mantel/trim clearances shown in the instruction manual. My inspector is going to go by what is called for in the manual, so I need a bit of clarification if anybody can help.
My plan is to have the stove on a steel hearth plate on top of the laminate floor.
The stove will sit 11" away from back wall (about where it is in picture)and will vent from behind - out the wall directly behind stove. (wall thimble)
The walls in the cabin are short (about 47"), so my existing wood beam can only be placed so high on that short wall. Manual/instructions call for unprotected surfaces 22" clearance for mantel, and 17" for top trim. My 7" tall by 3.5" thick mantel would only leave 19" of clearance from the top surface of the stove. I can only achieve 22" clearance if I use a shelf style mantel above that wall (just over the durock shown in pic), rather than a mantel fixed on the flat wall as originally planned.
I suppose I am asking... Is any wood mantel that I place on that short wall behind the stove going to need to be 22" ABOVE the stove top if it is over 1" thick?
Any insight/advice is appreciated! Thank you!
Here are some pics of the stove where it will be installed. Also included a pic of the mantle/trim clearance instructions.
