I can give you the number for my chimeny sweep dude, if you’re interested. He does all that stuff...Begreen, thanks for the tip. We have a very good dolly, and a nephew that is 6’8” that can help. I now have to clean the basement! Lol. Need to figure out how to plug the hole chimney hole and put a new one in the chimney around the side from the abandoned hole.
With a stainless steel liner installed plugging the old hole is mostly cosmetic.Begreen, thanks for the tip. We have a very good dolly, and a nephew that is 6’8” that can help. I now have to clean the basement! Lol. Need to figure out how to plug the hole chimney hole and put a new one in the chimney around the side from the abandoned hole.
So you don't think it will weaken the chimney structure to have 3 holes on 3 sides of the chimney? The hole next to the propane furnace can't be reached to patch. I thought patching the exposed hole would maintain the integrity of the chimney stack.With a stainless steel liner installed plugging the old hole is mostly cosmetic.
That is great to hear. We are not adversed to taking things apart and putting them back together. Begreen had some good moving tips too.Congratulations!
If it's anything like the F55, which I think it is, many parts can be removed easily to making moving less awkward.
We had the whole stove stripped down to the stainless steel box, moved it inside, and then back together in a little over an hour.
This allowed myself and my 62 year-old dad to carry it around.
I want to thank Stinkypickle for sending me on this mission to look at stoves! He told me about an Osburn, but it ended up too big to navigate our stairway. The Jotul, was sitting next to it, and I made a bid, the shop counter bid, then I bought it. Thanks StinkyAnd thanks for the lead information on the sweep. I will message you!
Rosem, do you have any more info regarding taking it apart? What type and sized tools did you use. I have a small metric ratchet set, up to 11mm. Does it need a large ratchet set? I am planning on picking it up tomorrow and would like to take it apart at the shop. Wrap the cast iron in blankets, set them in the bed of the truck, and stand the steel box. Does that sound reasonable?Congratulations!
No wood stove new or old should do that. If they go there are some serious problems. Coal can do that but it should only be from coal dust not from actually burning it.How much soot and dust does this stove create? If it were in the living area, would it cause a sooty layer on my walls? Or is that the old school stoves that did that?
You see where this is going....
