Jotul f-400 Castine
hyper2
2
West Babylon, NY
Hi everyone,
I am a new member here and look forward to what seems to be a wealth of info on the ins and outs of wood stoves and the "art" of using wood for a heat source.
I have recently acquired a Jotul f-400 Castine double door stove in very good condition. I noticed that there were no firebrick in the rear, though the schematic that accompanied the stove illustrates 3 vertical firebrick against the rear plate. My question is does the stove require the brick and if so do they just stand up in place on their own as there is no sort of retention bracket to hold them in place.
Thank you, Monty
Hi everyone,
Thank you, Monty
There should be firebrick behind the rear plate. They will not be exposed directly to the firebox. If you remove that rear plate, they will be free standing.
Thank you so much for your reply. I thought it strange that the back plate had a sort of sun burst design and the schematic actual lshowed the brick in front of back plate. Very deceiving! Thanks again
No problem at all. Theoretically the bricks won't really ever need replacing. Even if they crack, they will be held together by the plate. Unless they start to crack in multiple places, I wouldn't worry about it.
Enjoy the stove!
