I have Jotul DV 600 Firelight Propane Stove with a 23' verticle chimney and a 3' horizontal thimble and a 3' verticle stove pipe comming from the stove to the thimble in the wall.
Am I reading the chart in the owners manual correctly when it says that with this amount of verticle chimney, that the exhaust restrictor should be nearly closed?
The stove burns great, but I am wondering if too much heat is going up my linner with it currently set at half opened position.
On the flip side, would closing this restrictor more, possibly burn out this restrictor or give it the bad feature of a non vent unit?
All of it's heat comes from the top of the unit and the front glass. The sides are barely warm.
It does have a blower and brick kit installed.
The installer left it wide opened.
Thanks,
LB
Thanks,
LB
