Jotul Combifire #4 rust
Vermontyurt
10
Lunenburg Vermont
Hello All,
Just purchased a 1980's vintage Combifire #4. It has been sitting for many years without being used. There is rust on all unpainted areas inside the fire chamber and on the underside of the unit. I don't believe this unit has ever been fired!
I was thinking of taking a metal brush to everything and then apply a mixture of linseed oil/mineral oil to prevent further rust.
Any thoughts on other options?
Wire brush it down, a wire brush on a drill helps. Then wipe it down with alcohol and paint with a good stove paint like Forest Product's Stove Brite paint. Be sure to wear a mask when wire brushing and paint in a very well ventilated area. The fumes from the Stove Brite paint will rot brain cells.
Thank you!
I was thinking more of the underside and exterior to halt the rust. The interior of the stove would be fine with a spray of vegetable oil or just a wire brushing.
Danger, Danger Will Robinson!
Reactions: Lake Girl
Vermontyurt, I think it is on (broken link removed to http://www.jotul.us) under old manuals. The name is the tricky part. It is listed under combifire 1a.
That manual is for the Combifire 1A.
[Hearth.com] Jotul Combifire #4 rust
It's better to go by the clearances listed on the UL tag on the back of the stove.
