Hi All - new to the forum but have been searching and reading for a couple of months.
Looking to install an insert to supplement heat in a 1350 sf home I recently purchased. I think have narrowed the selection down but then I find other inserts that might fit the bill. I would like to be able to run a brush up the flue from inside the insert, the units listed below appear to be obstruction free once the baffles are removed.. Flush mount is important as well as a large viewing area. I do like the double doors but not a requirement. The models I have gotten down to are:
Fireplace extrordinair 33 elite
Jotul C 550
Napoleon 1101
Any input would be greatly appreciated. Also, any news on new units coming out? Are other units, i.e. VC Montpelier or Quadrafire Voyager able to have their flues cleaned from inside the stove?
Can clearances always be reduced by using a heat shield? My mantle sticks out 3.5" and is 46.5" from the hearth. The only unit that wouldn't need a shield appears to be the Elite 33. I was also told by a dealer that he wouldn't even sell me the Montpelier because it needs 47.5" to the mantle and has not been certified any other way. Is this True?
Fire place dimensions are:
40"w in the front 28" w in the rear
27h
21"d at the bottom but gently slopes to 18" at the top(appears to start sloping approx 21"
46.5" Hearth to mantle
Thanks!
ps been burning wood for 28 years - Dutchwest medium CAT
Jotul C 550
Napoleon 1101
27h
Thanks!
