Hello,
Hoo boy, I am at my wit's end with this one. To actually post in a forum!
The house I am in now has a Jotul Alpha, and while it's in pretty good shape, not having been used too much by the previous owners (they preferred the diesel burner) at one point last season I noticed some gasket material hanging down. A quick inspection indicated that the gasket for the bypass door was compromised. The manual lists it as part #126885, and I assume it is a fitted piece, and it mentions special adhesive. However, no source for this has been found, and while I was moderately successful at reaching up in there with my fingers, only part of my new gasket stayed put ... and I attacked it again today, thinking access from the top would also grant me enough ability to clean the groove and replace the gasket without getting mire gasket stuck to my fingers, etc. .. but ... no luck.
Without taking the whole stove apart, does anyone have any tricks for this? If I wasn't short of money I'd replace the whole stove . It made heat last year, but not a lot ... frankly, other than burning clean and fairly long (not like a Blaze King, sadly) it was so cold behind the stove that I had trouble keeping my bottles of homebrew at 70F while bottle conditioning .. .and they were stacked right behind it!
So I'm hoping that if I can get this gasket fully and reliably installed, it will make more heat (yeah, like the Blaze King)
Fingers crossed for a magic trick! (because they need to be crossed to even access that area)
Cheers, and thanks!
Gene
Cheers, and thanks!
Gene
