I had a Jotul Allagash installed in Feb 2018. Worked fine that winter, but I've been having problems with the unit since this fall, namely that it won't stay lit if it is not in regular use. The fireplace is at a weekend house. If we go more than a week or so without turning it on, the unit will fire up but then flame sputters out after 10-15 minutes. The installer provided the following explanation: "These gas fireplaces are like luxury cars. They need to be driven occasionally or they don't perform properly." His solution is essentially to pound on the gas valve with a rubber mallet to knock loose any build up and keep gas flowing properly.
I'm looking for some independent verification that this is actually a valid explanation and expected performance of the stove. Needless to say, I'm not happy about spending this much money on something that is so finicky.
Thanks for the help.
Jeff
Jeff
