Jotul 600
koavt
16
VT
I have a Jotul 600. I replaced the gaskets on the left front door only due to extreme wear on the center gasket. The right door gasket looks fine. Do I need to replace gasketing on both doors?
As a matter of course, I would also replace the ash pan gasket and the side door gasket. All three of these are wear/seal items, assuming you have been using the side door. (The center does wear faster if used because it is a smaller gasket on a narrower flange.)
The standard Jotul kit will include the gasket material for all three locations.
