Jotul 600 door replacement
josephorpen
5
Devon
Hi,
I have a green Jotul 600 in my horsebox conversion.
I’ve been looking at buying a glass lattice 602 door (as pictured) and wondered if this would fit / work on my stove.
Any help would be appreciaeted.
Thanks,
Joseph
[Hearth.com] Jotul 600 door replacement [Hearth.com] Jotul 600 door replacement [Hearth.com] Jotul 600 door replacement [Hearth.com] Jotul 600 door replacement
No. The door on the F602 has flat sides, so the door is flat & small. The F600 has rounded sides & Doors. The sealing gaskets on the 602 door won’t seal the fire box on the 600.
Reactions: josephorpen
Bugger. Thanks for your reply 👍🏼 ill stick with what I have then.
That's a beautiful color. I have not seen a Jotul in wine bottle green before. Was the stove restored?
Thank you, yes it’s a beaut isn’t it! I believe this is the original colour but they only released a limited amount. The stove was cleaned up by a restored but it was in great condition. It matches the colour of our truck - see photo 😊👍🏼
It looks like a nice cabin setting for the stove, though I am concerned about the short hearth and proximity of the divan in front of it. In the US the stove would require 16" of hearth in front of the stove door and 36" to any combustible in front. Embers can pop out of the stove unexpectedly when the door is open. If the stove is to be run sometimes with the door open then a firescreen should be made to fit it safely. Is the floor brick or other non-combustible material?
Thanks. The door is rarely opened, just for a photo such as these 👍🏼 Never had any issues in all the years ive used it but appreciate your concern
